Saltar al contenido principal
Samsung Captivate Rear Case Replacement
Qué necesitas
  1. Samsung Captivate Rear Case Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Rear Case Replacement: paso 2, imagen 1 de 1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Rear Case Replacement: paso 3, imagen 1 de 1
    • Replace the old battery with the new one.
  4. Samsung Captivate Rear Case Replacement, Rear Case: paso 4, imagen 1 de 1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Rear Case Replacement: paso 5, imagen 1 de 1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Rear Case Replacement: paso 6, imagen 1 de 3 Samsung Captivate Rear Case Replacement: paso 6, imagen 2 de 3 Samsung Captivate Rear Case Replacement: paso 6, imagen 3 de 3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Rear Case Replacement: paso 7, imagen 1 de 1
    • Separate the rear case from the phone.
Conclusión
12 personas más completaron esta guía.
Christopher
Miembro Desde 10/06/11
643 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 20-25, Maness Fall 2011 Miembro de Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 3,543
