Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Captivate Glide Screen Replacement
Qué necesitas
  1. Samsung Captivate Glide Screen Replacement, Motherboard: paso 1, imagen 1 de 3 Samsung Captivate Glide Screen Replacement, Motherboard: paso 1, imagen 2 de 3 Samsung Captivate Glide Screen Replacement, Motherboard: paso 1, imagen 3 de 3
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Samsung Captivate Glide Screen Replacement: paso 2, imagen 1 de 2 Samsung Captivate Glide Screen Replacement: paso 2, imagen 2 de 2
    • Remove battery with plastic opening tool or finger.
  3. Samsung Captivate Glide Screen Replacement: paso 3, imagen 1 de 2 Samsung Captivate Glide Screen Replacement: paso 3, imagen 2 de 2
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Samsung Captivate Glide Screen Replacement: paso 4, imagen 1 de 3 Samsung Captivate Glide Screen Replacement: paso 4, imagen 2 de 3 Samsung Captivate Glide Screen Replacement: paso 4, imagen 3 de 3
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Samsung Captivate Glide Screen Replacement: paso 5, imagen 1 de 2 Samsung Captivate Glide Screen Replacement: paso 5, imagen 2 de 2
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  6. Samsung Captivate Glide Screen Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Disconnect the antenna cable from the motherboard using tweezers.
  7. Samsung Captivate Glide Screen Replacement: paso 7, imagen 1 de 1
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  8. Samsung Captivate Glide Screen Replacement: paso 8, imagen 1 de 2 Samsung Captivate Glide Screen Replacement: paso 8, imagen 2 de 2
    • Lift the motherboard out of the base of the phone.
  9. Samsung Captivate Glide Screen Replacement, Screen: paso 9, imagen 1 de 2 Samsung Captivate Glide Screen Replacement, Screen: paso 9, imagen 2 de 2
    • Remove the eight screws with the #00 screwdriver.
  10. Samsung Captivate Glide Screen Replacement: paso 10, imagen 1 de 2 Samsung Captivate Glide Screen Replacement: paso 10, imagen 2 de 2
  11. Samsung Captivate Glide Screen Replacement: paso 11, imagen 1 de 1
    • Remove screws with the #00 screwdriver.
  12. Samsung Captivate Glide Screen Replacement: paso 12, imagen 1 de 1
    • Using the plastic opening tool, remove the back plate by prying on the four main points.
    • You may encounter difficultly at certain points. Work the plastic opening tool along the edge to keep back plate from closing again.
  13. Samsung Captivate Glide Screen Replacement: paso 13, imagen 1 de 1
    • Lift the back plate.
    • To remove to slide flex cable, gently peel back from the back plate and remove back plate.
  14. Samsung Captivate Glide Screen Replacement: paso 14, imagen 1 de 3 Samsung Captivate Glide Screen Replacement: paso 14, imagen 2 de 3 Samsung Captivate Glide Screen Replacement: paso 14, imagen 3 de 3
    • Slide the flex cable through the slot. Be careful to not tear the cable.
    • Set the front plate down.
  15. Samsung Captivate Glide Screen Replacement: paso 15, imagen 1 de 2 Samsung Captivate Glide Screen Replacement: paso 15, imagen 2 de 2
    • Remove the four corner screws using the #00 screwdriver.
  16. Samsung Captivate Glide Screen Replacement: paso 16, imagen 1 de 3 Samsung Captivate Glide Screen Replacement: paso 16, imagen 2 de 3 Samsung Captivate Glide Screen Replacement: paso 16, imagen 3 de 3
    • Using the plastic opening tool, release all the clips on all four sides holding the screen assembly.
    • You can now remove the back plate by sliding the flex cable through the slot.
  17. Samsung Captivate Glide Screen Replacement: paso 17, imagen 1 de 3 Samsung Captivate Glide Screen Replacement: paso 17, imagen 2 de 3 Samsung Captivate Glide Screen Replacement: paso 17, imagen 3 de 3
    • Use the plastic opening tool to release the main jaw connector, front speaker and camera.
  18. Samsung Captivate Glide Screen Replacement: paso 18, imagen 1 de 2 Samsung Captivate Glide Screen Replacement: paso 18, imagen 2 de 2
    • By using the plastic opening tool you can release the keypad flex cable from the jaw connecter clamp.
  19. Samsung Captivate Glide Screen Replacement: paso 19, imagen 1 de 2 Samsung Captivate Glide Screen Replacement: paso 19, imagen 2 de 2
    • Use a heat gun or blow dryer.
    • Heat the outside edges using quick movements for about 45 seconds.
  20. Samsung Captivate Glide Screen Replacement: paso 20, imagen 1 de 3 Samsung Captivate Glide Screen Replacement: paso 20, imagen 2 de 3 Samsung Captivate Glide Screen Replacement: paso 20, imagen 3 de 3
    • Using the plastic opening tool to pry around the edges, release the touch screen from the screen frame.
  21. Samsung Captivate Glide Screen Replacement: paso 21, imagen 1 de 3 Samsung Captivate Glide Screen Replacement: paso 21, imagen 2 de 3 Samsung Captivate Glide Screen Replacement: paso 21, imagen 3 de 3
    • While adhesive is still warm, use the plastic opening tool to gently remove the keyboard flex cable from the screen.
    • You can now replace the screen assembly.
Conclusión
2 personas más completaron esta guía.
Tyler Moore
Miembro Desde 09/23/14
160 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 5-3, Mcgee Fall 2014 Miembro de USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
Miembros de 4
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 38
Todo El Tiempo: 1,263
