Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Captivate Glide QWERTY Keyboard Replacement
Qué necesitas
  1. Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: paso 1, imagen 1 de 3 Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: paso 1, imagen 2 de 3 Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Samsung Captivate Glide QWERTY Keyboard Replacement: paso 2, imagen 1 de 2 Samsung Captivate Glide QWERTY Keyboard Replacement: paso 2, imagen 2 de 2
    • Remove battery with plastic opening tool or finger.
  3. Samsung Captivate Glide QWERTY Keyboard Replacement: paso 3, imagen 1 de 2 Samsung Captivate Glide QWERTY Keyboard Replacement: paso 3, imagen 2 de 2
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Samsung Captivate Glide QWERTY Keyboard Replacement: paso 4, imagen 1 de 3 Samsung Captivate Glide QWERTY Keyboard Replacement: paso 4, imagen 2 de 3 Samsung Captivate Glide QWERTY Keyboard Replacement: paso 4, imagen 3 de 3
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Samsung Captivate Glide QWERTY Keyboard Replacement: paso 5, imagen 1 de 2 Samsung Captivate Glide QWERTY Keyboard Replacement: paso 5, imagen 2 de 2
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  6. Samsung Captivate Glide QWERTY Keyboard Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Disconnect the antenna cable from the motherboard using tweezers.
  7. Samsung Captivate Glide QWERTY Keyboard Replacement: paso 7, imagen 1 de 1
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  8. Samsung Captivate Glide QWERTY Keyboard Replacement: paso 8, imagen 1 de 2 Samsung Captivate Glide QWERTY Keyboard Replacement: paso 8, imagen 2 de 2
    • Lift the motherboard out of the base of the phone.
  9. Samsung Captivate Glide QWERTY Keyboard Replacement, QWERTY Keyboard: paso 9, imagen 1 de 2 Samsung Captivate Glide QWERTY Keyboard Replacement, QWERTY Keyboard: paso 9, imagen 2 de 2
    • Remove the eight screws using the #00 screw driver.
  10. Samsung Captivate Glide QWERTY Keyboard Replacement: paso 10, imagen 1 de 2 Samsung Captivate Glide QWERTY Keyboard Replacement: paso 10, imagen 2 de 2
  11. Samsung Captivate Glide QWERTY Keyboard Replacement: paso 11, imagen 1 de 1
    • Remove screws using the #00 screwdriver.
  12. Samsung Captivate Glide QWERTY Keyboard Replacement: paso 12, imagen 1 de 1
    • Using the plastic opening tool, remove the back plate by prying on the four main points.
    • You may encounter difficultly at certain points. Work the plastic opening tool along the edge to keep back plate from closing again.
  13. Samsung Captivate Glide QWERTY Keyboard Replacement: paso 13, imagen 1 de 1
    • Lift the back plate.
    • To remove the attached flex cable, gently peel the flex cable connecting to the back plate.
    • Flex cable is attached to the back plate with an adhesive.
  14. Samsung Captivate Glide QWERTY Keyboard Replacement: paso 14, imagen 1 de 3 Samsung Captivate Glide QWERTY Keyboard Replacement: paso 14, imagen 2 de 3 Samsung Captivate Glide QWERTY Keyboard Replacement: paso 14, imagen 3 de 3
    • Slide the flex cable through the slot.
    • Set the front plate down. Now you have free access to the keyboard.
  15. Samsung Captivate Glide QWERTY Keyboard Replacement: paso 15, imagen 1 de 1
    • Manually lift the keyboard and replace with new keyboard.
    • Make sure the new keyboard is placed with the keyboard letters facing down, and the white back facing up.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team 5-3, Mcgee Fall 2014 Miembro de USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
Miembros de 4
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 36
Todo El Tiempo: 660
