Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Captivate Glide Camera Replacement
Qué necesitas
  1. Samsung Captivate Glide Camera Replacement, Motherboard: paso 1, imagen 1 de 3 Samsung Captivate Glide Camera Replacement, Motherboard: paso 1, imagen 2 de 3 Samsung Captivate Glide Camera Replacement, Motherboard: paso 1, imagen 3 de 3
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Samsung Captivate Glide Camera Replacement: paso 2, imagen 1 de 2 Samsung Captivate Glide Camera Replacement: paso 2, imagen 2 de 2
    • Remove battery with plastic opening tool or finger.
  3. Samsung Captivate Glide Camera Replacement: paso 3, imagen 1 de 2 Samsung Captivate Glide Camera Replacement: paso 3, imagen 2 de 2
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Samsung Captivate Glide Camera Replacement: paso 4, imagen 1 de 3 Samsung Captivate Glide Camera Replacement: paso 4, imagen 2 de 3 Samsung Captivate Glide Camera Replacement: paso 4, imagen 3 de 3
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Samsung Captivate Glide Camera Replacement: paso 5, imagen 1 de 2 Samsung Captivate Glide Camera Replacement: paso 5, imagen 2 de 2
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  6. Samsung Captivate Glide Camera Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Disconnect the antenna cable from the motherboard using tweezers.
  7. Samsung Captivate Glide Camera Replacement: paso 7, imagen 1 de 1
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  8. Samsung Captivate Glide Camera Replacement: paso 8, imagen 1 de 2 Samsung Captivate Glide Camera Replacement: paso 8, imagen 2 de 2
    • Lift the motherboard out of the base of the phone.
  9. Samsung Captivate Glide Camera Replacement, Camera: paso 9, imagen 1 de 3 Samsung Captivate Glide Camera Replacement, Camera: paso 9, imagen 2 de 3 Samsung Captivate Glide Camera Replacement, Camera: paso 9, imagen 3 de 3
    • Using the opening tool, pry up the camera attachment from the motherboard.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 5-3, Mcgee Fall 2014 Miembro de USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
Miembros de 4
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 832
