Saltar al contenido principal
Samsung CLP-300 Imaging Unit Replacement
  1. Samsung CLP-300 Imaging Unit Replacement, Imaging Unit: paso 1, imagen 1 de 1
    • Turn the printer off and wait a few minutes for it to cool.
  2. Samsung CLP-300 Imaging Unit Replacement: paso 2, imagen 1 de 2 Samsung CLP-300 Imaging Unit Replacement: paso 2, imagen 2 de 2
    • Open the front cover
  3. Samsung CLP-300 Imaging Unit Replacement: paso 3, imagen 1 de 1
    • Remove waste toner container from the printer.
  4. Samsung CLP-300 Imaging Unit Replacement: paso 4, imagen 1 de 3 Samsung CLP-300 Imaging Unit Replacement: paso 4, imagen 2 de 3 Samsung CLP-300 Imaging Unit Replacement: paso 4, imagen 3 de 3
    • Pull the imaging unit out of the printer using bottom handle.
    • Use green handle on top of imaging unit to steady unit as you pull it out.
    • Holding the top and bottom handles on the new imaging unit, slide the unit in the printer until you hear a “click.”
    • Remove new imaging unit from its packaging making sure to remove protective paper and devices from unit
    • Do not expose new imaging unit to light for more than a few minutes. Covering unit with a piece of paper is sufficient protection while you complete repair.
    • If you hear a crackling sound once the printer turns on the imaging unit is not installed correctly. Take out and reinsert the unit.
Conclusión
2 personas más completaron esta guía.
Heather Howard
Miembro Desde 10/15/14
586 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 22
Todo El Tiempo: 13,120
