Saltar al contenido principal
Introducción
I noticed that there was not to much information about working on this phone. I received one in a non-working condition and figured it would be a good chance for some guides. The phone is easy to work on and no hidden screws or clips, no excessive glue. A straight forward no nonsense phone.
Partes
No se especificaron partes.
  1. Here is the Samsung SCH-U380 Brightside Turn it over to gain access to the battery. Remove the backcover by simply pulling it off the phone from the top down
    • Here is the Samsung SCH-U380 Brightside
    • Turn it over to gain access to the battery.
    • Remove the backcover by simply pulling it off the phone from the top down
  2. Remove the battery Remove the six Phillips screws from the back frame All six screws are identical M1.5X3
    • Remove the battery
    • Remove the six Phillips screws from the back frame
    • All six screws are identical M1.5X3
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips Continue to slide the tool along the slot until you feel the plastic locks disengage Once all locks have released, the bottom frame can simply be removed.
    • Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
    • Continue to slide the tool along the slot until you feel the plastic locks disengage
    • Once all locks have released, the bottom frame can simply be removed.
  5. Remove the two Phillips screws from the EMI shield. Both screws are identical M1.5X2 Remove the EMI shield
    • Remove the two Phillips screws from the EMI shield.
    • Both screws are identical M1.5X2
    • Remove the EMI shield
  6. Detach the LCD connector. Remove the logic board
    • Detach the LCD connector.
    • Remove the logic board
Conclusión
Una persona más ha completado esta guía.
oldturkey03
Miembro Desde 29/09/10
592,539 Reputación
102 Guías creadas
Equipo
OTS Miembro de OTS
Business
1 Miembro
130 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 1,105
