Saltar al contenido principal
Samsung Blast Motherboard Replacement
Qué necesitas
  1. Samsung Blast Motherboard  Replacement, Motherboard: paso 1, imagen 1 de 2 Samsung Blast Motherboard  Replacement, Motherboard: paso 1, imagen 2 de 2
    • Remove the battery cover by pushing it upwards.
  2. Samsung Blast Motherboard  Replacement: paso 2, imagen 1 de 1
    • Take out the battery.
  3. Samsung Blast Motherboard  Replacement: paso 3, imagen 1 de 1
    • With a Phillips #00 screwdriver, remove the six screws that secure the back of the case.
    • You will not be able to completely remove the top two screws. Simply loosen them enough that you can still remove the cover.
  4. Samsung Blast Motherboard  Replacement: paso 4, imagen 1 de 1
    • Pull off the back cover of the phone.
  5. Samsung Blast Motherboard  Replacement: paso 5, imagen 1 de 2 Samsung Blast Motherboard  Replacement: paso 5, imagen 2 de 2
    • Remove the volume and camera buttons by pulling them out.
    • Put the buttons aside until it is time to reassemble the phone.
  6. Samsung Blast Motherboard  Replacement: paso 6, imagen 1 de 1
    • Use the small plastic opening tool to gently remove the motherboard from the rest of the phone.
  7. Samsung Blast Motherboard  Replacement: paso 7, imagen 1 de 2 Samsung Blast Motherboard  Replacement: paso 7, imagen 2 de 2
    • Gently grab the motherboard with tweezers, then disconnect it from the two attached plates.
Conclusión
Una persona más ha completado esta guía.
Equipo
Ohio State, Team 1-5, Buehl Spring 2014 Miembro de Ohio State, Team 1-5, Buehl Spring 2014
OSU-BUEHL-S14S1G5
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 6
Todo El Tiempo: 312
