Saltar al contenido principal
Samsung Blast Keyboard Replacement
Qué necesitas
  1. Samsung Blast Keyboard Replacement, At a Glance: paso 1, imagen 1 de 2 Samsung Blast Keyboard Replacement, At a Glance: paso 1, imagen 2 de 2
    • Your phone should look like this before disassembly.
  2. Samsung Blast Keyboard Replacement, Battery Case Removal: paso 2, imagen 1 de 2 Samsung Blast Keyboard Replacement, Battery Case Removal: paso 2, imagen 2 de 2
    • Remove the battery cover by sliding the back panel up. This will expose the battery.
  3. Samsung Blast Keyboard Replacement, Remove Battery/Sim card: paso 3, imagen 1 de 1
    • Lift up the top portion of the battery and pull it out.
    • Next, slide the sim card out of its socket and set it aside.
  4. Samsung Blast Keyboard Replacement, Back Case Removal: paso 4, imagen 1 de 2 Samsung Blast Keyboard Replacement, Back Case Removal: paso 4, imagen 2 de 2
    • Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case.
    • The top two screws are connected to the back cover. They will not come off once unscrewed.
    • Remove the case by prying around the edges.
    • Note the positions of button pads for reassembly.
  5. Samsung Blast Keyboard Replacement, Button Pads: paso 5, imagen 1 de 2 Samsung Blast Keyboard Replacement, Button Pads: paso 5, imagen 2 de 2
    • Remove the buttons for the camera and volume.
  6. Samsung Blast Keyboard Replacement, Motherboard Removal: paso 6, imagen 1 de 3 Samsung Blast Keyboard Replacement, Motherboard Removal: paso 6, imagen 2 de 3 Samsung Blast Keyboard Replacement, Motherboard Removal: paso 6, imagen 3 de 3
    • Use a prying tool to detach the motherboard from main body.
    • Carefully detach the motherboard from the two connectors.
    • You could also use a pry tool for the second step.
    • Be careful with the motherboard as not to scrape or damage its components.
  7. Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: paso 7, imagen 1 de 2 Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: paso 7, imagen 2 de 2
    • Slide the keyboard straight up to free it from its alignment pins.
    • Swap the broken keyboard with a replacement here, and follow the repair steps in reverse order for reassembly.
Conclusión
Jordan Taylor
Miembro Desde 02/11/14
10 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-5, Buehl Spring 2014 Miembro de Ohio State, Team 1-5, Buehl Spring 2014
OSU-BUEHL-S14S1G5
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 283
