Saltar al contenido principal
Samsung Blast Back Cover Replacement
Qué necesitas
  1. Samsung Blast Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Place the phone face down on the table. Locate a Phillips head screwdriver. Begin by first removing the four screws that surround the upper area of the Samsung phone.
  2. Samsung Blast Back Cover Replacement: paso 2, imagen 1 de 1
    • Next, remove the side button by prying open the the side of the phone with a prying tool. Insert the prying tool between the back cover and the remainder of the phone. Slide the prying tool to the left, creating a division between the cover and the phone.
  3. Samsung Blast Back Cover Replacement: paso 3, imagen 1 de 1
    • Continue using the prying tool to unlock the phone. If you hear a popping sound you know that you are on the right track. Be gentle as to not snap the screw-posts inside the case.
  4. Samsung Blast Back Cover Replacement: paso 4, imagen 1 de 1
    • Finally, remove the back cover by gently lifting the case up, ensuring that nothing is still attached to the cover.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 176
