Saltar al contenido principal
Samsung Blackjack Volume/Scroll Wheel Replacement
Qué necesitas
  1. Samsung Blackjack Volume/Scroll Wheel Replacement, Battery Cover: paso 1, imagen 1 de 3 Samsung Blackjack Volume/Scroll Wheel Replacement, Battery Cover: paso 1, imagen 2 de 3 Samsung Blackjack Volume/Scroll Wheel Replacement, Battery Cover: paso 1, imagen 3 de 3
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  2. Samsung Blackjack Volume/Scroll Wheel Replacement, Battery: paso 2, imagen 1 de 2 Samsung Blackjack Volume/Scroll Wheel Replacement, Battery: paso 2, imagen 2 de 2
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
  3. Samsung Blackjack Volume/Scroll Wheel Replacement, SIM Card: paso 3, imagen 1 de 3 Samsung Blackjack Volume/Scroll Wheel Replacement, SIM Card: paso 3, imagen 2 de 3 Samsung Blackjack Volume/Scroll Wheel Replacement, SIM Card: paso 3, imagen 3 de 3
    • Place your thumb on the SIM card.
    • Slide the card out of the slot.
  4. Samsung Blackjack Volume/Scroll Wheel Replacement, Back Phone Casing: paso 4, imagen 1 de 2 Samsung Blackjack Volume/Scroll Wheel Replacement, Back Phone Casing: paso 4, imagen 2 de 2
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  5. Samsung Blackjack Volume/Scroll Wheel Replacement: paso 5, imagen 1 de 3 Samsung Blackjack Volume/Scroll Wheel Replacement: paso 5, imagen 2 de 3 Samsung Blackjack Volume/Scroll Wheel Replacement: paso 5, imagen 3 de 3
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
  6. Samsung Blackjack Volume/Scroll Wheel Replacement, Volume/Scroll Wheel: paso 6, imagen 1 de 2 Samsung Blackjack Volume/Scroll Wheel Replacement, Volume/Scroll Wheel: paso 6, imagen 2 de 2
    • Use the screwdriver to unscrew the four screws that hold the scroll wheel in place.
    • Use your fingers to remove the scroll wheel and the metal plate that it is attached to.
  7. Samsung Blackjack Volume/Scroll Wheel Replacement: paso 7, imagen 1 de 2 Samsung Blackjack Volume/Scroll Wheel Replacement: paso 7, imagen 2 de 2
    • Use the spudger to unsnap the gold wire connection that connects the back casing to the logic board.
    • Use the spudger to unsnap the gold wire connection that connects the scroll wheel assembly to the logic board.
Conclusión
Kristin Manna
Miembro Desde 10/22/12
29 Reputación
10 Guías creadas
Equipo
Clemson, Team 14-4, Benson Fall 2012 Miembro de Clemson, Team 14-4, Benson Fall 2012
CLEM-BENSON-F12S14G4
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 436
