Introducción
Use this guide to replace the back phone case and to remove the casing to access the inside of the phone.
Partes
No se requieren partes.
  1. Hold the device with the screen facing away from you and the camera towards you. Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover. Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  2. Place your fingers on both sides of the bottom of the battery and lift upwards. Pull the battery away from the phone.
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Place your thumb on the SIM card. Slide the card out of the slot. Slide the card out of the slot.
    • Place your thumb on the SIM card.
    • Slide the card out of the slot.
  5. Use the spudger to remove the rubber stoppers from the top of the cover. Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  6. Use the spudger to loosen and separate the front and back covers. Pick up the back cover once loosened. The front and back covers will be attached to each other by a gold wire.
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
Conclusión
Kristin Manna
Miembro Desde 22/10/12
17 Reputación
10 Guías creadas
Equipo
Clemson, Team 14-4, Benson Fall 2012 Miembro de Clemson, Team 14-4, Benson Fall 2012
CLEM-BENSON-F12S14G4
3 Miembros
12 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 401
