Introducción
Use this guide to remove the front casing and to access the keypad.
Qué necesitas
Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
Pry apart the plastic tabs along the edges of the phone.
Separate the front panel from the main body of the phone using your fingers.
Una persona más ha completado esta guía.
