Introducción
Follow this guide to replace a broken or faulty open button on your Samsung BD-JM57C Blu ray player.
The open button on the Blu-ray player allows all the disc tray to open and close, allowing you to insert a DVD or Blu-ray disc. A broken or faulty open button will prohibit the disc tray from operating.
Before taking apart the Blu-ray player and replacing the open button, look at the troubleshooting page for the Samsung BD-JM57C and see if your problem can be resolved.
Make sure the device is not plugged in before working on it.
Soldering is a requirement to complete this guide. Use the How to Solder and Desolder Connections guide for more information on soldering.
Qué necesitas
Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
Remove the cover by sliding it up and then out.
Disconnect the two ribbons that connect the disc drive to the motherboard.
Pull clip to remove the WiFi card ribbon connected to the circuit board.
Push the black plastic tab out and slide the WiFi card out from the cage.
Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
Lift the cage up to remove it.
After the power cord has been disconnected, remove the yellow circuit board from the Blu ray player.
2 personas más completaron esta guía.
