Introducción
The blu-ray player will be opened and the power cord, the DC power board, and the motherboard will be removed.
Qué necesitas
Remove the 7 mm screw using a phillips head #J1 screwdriver.
To remove the ribbon cable, firmly grip the blue tab attached to the base and pull upwards.
To remove the three ribbon cables connected to the mother board, firmly grip the blue tab attached to the base and pull upwards.
To remove the small, three wire connector, pinch the tab at the base of the wires and pull upwards.
Una persona más ha completado esta guía.
