Saltar al contenido principal
Samsung BD-F7500 Blu-ray Player Disc Tray Replacement
Qué necesitas
  1. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement, Disc Tray: paso 1, imagen 1 de 2 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement, Disc Tray: paso 1, imagen 2 de 2
    • Use a Phillips head #J1 screwdriver to remove all three (3) 10 mm screws.
  2. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: paso 2, imagen 1 de 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: paso 2, imagen 2 de 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: paso 2, imagen 3 de 3
    • To remove each ribbon cable, firmly grip the hard plastic tab attached to the base and pull upwards.
    • Be careful not to tear the ribbon cables.
  3. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: paso 3, imagen 1 de 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: paso 3, imagen 2 de 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: paso 3, imagen 3 de 3
    • Using a screwdriver with a #J1 bit, remove the two (2) 7 mm screws.
  4. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: paso 4, imagen 1 de 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: paso 4, imagen 2 de 3 Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: paso 4, imagen 3 de 3
    • Locate the two black tabs on each side of the disc tray. The second tab is located in the same location on opposite side of marked tab.
    • While pinching both tabs, slightly push the disc tray towards the front of the device, and lift the disc tray out.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 705
