Saltar al contenido principal
Samsung BD-F5900 Main Logic Board Replacement
Qué necesitas
  1. Samsung BD-F5900 Main Logic Board Replacement, Top Cover: paso 1, imagen 1 de 1
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Samsung BD-F5900 Main Logic Board Replacement: paso 2, imagen 1 de 1
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Samsung BD-F5900 Main Logic Board Replacement, Power Supply: paso 3, imagen 1 de 2 Samsung BD-F5900 Main Logic Board Replacement, Power Supply: paso 3, imagen 2 de 2
    • Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover.
  4. Samsung BD-F5900 Main Logic Board Replacement: paso 4, imagen 1 de 1
    • Press down on the plastic retaining clip and pull backwards to remove the AC power connector from the power supply board.
  5. Samsung BD-F5900 Main Logic Board Replacement: paso 5, imagen 1 de 3 Samsung BD-F5900 Main Logic Board Replacement: paso 5, imagen 2 de 3 Samsung BD-F5900 Main Logic Board Replacement: paso 5, imagen 3 de 3
    • Using the plastic spudger tool, gently pry on either side of main power connector (CON801) to disconnect from main logic board.
    • Pry a little bit on each side of board until the board lifts away.
    • Tilt the board forward and lift up to remove from the chassis.
  6. Samsung BD-F5900 Main Logic Board Replacement, Main Logic Board: paso 6, imagen 1 de 1
    • Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
    • Be careful not to damage the ribbon cable by using too much force.
  7. Samsung BD-F5900 Main Logic Board Replacement: paso 7, imagen 1 de 1
    • Disconnect the WiFi board cable connector
  8. Samsung BD-F5900 Main Logic Board Replacement: paso 8, imagen 1 de 2 Samsung BD-F5900 Main Logic Board Replacement: paso 8, imagen 2 de 2
    • Using a #1 Phillips head screwdriver, remove the three 7.5 mm screws from the board
    • Also remove the 10 mm screw from the rear panel.
    • Remove the Main Logic Board
Conclusión
Louis McKean
Miembro Desde 10/18/17
528 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G21, Cagle Fall 2017 Miembro de USF Tampa, Team S1-G21, Cagle Fall 2017
USFT-CAGLE-F17S1G21
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 409
