Saltar al contenido principal
Samsung BD-F5700 Disc Reader Replacement
Qué necesitas
  1. Samsung BD-F5700 Disc Reader Replacement, Power Cord: paso 1, imagen 1 de 3 Samsung BD-F5700 Disc Reader Replacement, Power Cord: paso 1, imagen 2 de 3 Samsung BD-F5700 Disc Reader Replacement, Power Cord: paso 1, imagen 3 de 3
    • Use Phillips 0 Screwdriver to remove two (2), 10 mm rear screws.
    • Use the iFixit opening tool to help separate the top plastic casing from the bottom metal casing.
    • When opening the device, be careful to not damage the ribbon cable circled in image 3.
  2. Samsung BD-F5700 Disc Reader Replacement: paso 2, imagen 1 de 3 Samsung BD-F5700 Disc Reader Replacement: paso 2, imagen 2 de 3 Samsung BD-F5700 Disc Reader Replacement: paso 2, imagen 3 de 3
    • Use Phillips 0 screwdriver to remove two (2), 10 mm screws from the plastic cover.
    • Remove plastic cover from board.
  3. Samsung BD-F5700 Disc Reader Replacement: paso 3, imagen 1 de 2 Samsung BD-F5700 Disc Reader Replacement: paso 3, imagen 2 de 2
    • Pull upward on back of the black and white wire to dislocate the black tab piece from device.
    • To remove the cord from the device entirely, press on the white tab in the device and gently pull.
  4. Samsung BD-F5700 Disc Reader Replacement: paso 4, imagen 1 de 1
    • Insert the iFixit Opening tool into the black tab on the power cord, and use leverage to open the black tab.
    • Pull the tab off the wire so that it can be placed on the replacement cord.
  5. Samsung BD-F5700 Disc Reader Replacement, Disc Reader: paso 5, imagen 1 de 3 Samsung BD-F5700 Disc Reader Replacement, Disc Reader: paso 5, imagen 2 de 3 Samsung BD-F5700 Disc Reader Replacement, Disc Reader: paso 5, imagen 3 de 3
    • Firmly grip the hard plastic tab attached to the base and pull upwards.
    • It is important to not tear the ribbon cables.
  6. Samsung BD-F5700 Disc Reader Replacement: paso 6, imagen 1 de 2 Samsung BD-F5700 Disc Reader Replacement: paso 6, imagen 2 de 2
    • Remove the two 7mm screws with a Phillips #1 screwdriver.
  7. Samsung BD-F5700 Disc Reader Replacement: paso 7, imagen 1 de 3 Samsung BD-F5700 Disc Reader Replacement: paso 7, imagen 2 de 3 Samsung BD-F5700 Disc Reader Replacement: paso 7, imagen 3 de 3
    • Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove.
  8. Samsung BD-F5700 Disc Reader Replacement: paso 8, imagen 1 de 3 Samsung BD-F5700 Disc Reader Replacement: paso 8, imagen 2 de 3 Samsung BD-F5700 Disc Reader Replacement: paso 8, imagen 3 de 3
    • Flip up the black locking tab on the ZIF connector.
  9. Samsung BD-F5700 Disc Reader Replacement: paso 9, imagen 1 de 3 Samsung BD-F5700 Disc Reader Replacement: paso 9, imagen 2 de 3 Samsung BD-F5700 Disc Reader Replacement: paso 9, imagen 3 de 3
    • Remove the 10 mm screw using a Phillips #1 screwdriver.
    • Remove the small metal bar by pulling it outwards.
  10. Samsung BD-F5700 Disc Reader Replacement: paso 10, imagen 1 de 2 Samsung BD-F5700 Disc Reader Replacement: paso 10, imagen 2 de 2
    • Flip the disc tray over so the laser points downward.
    • Pull the disc reader out of the disc tray.
Conclusión
2 personas más completaron esta guía.
Livan Perez
Miembro Desde 02/15/18
303 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S16-G4, Boczar Spring 2018 Miembro de USF Tampa, Team S16-G4, Boczar Spring 2018
USFT-BOCZAR-S18S16G4
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 15
Todo El Tiempo: 638
