Saltar al contenido principal
Samsung BD-F5700 DC Power Board Replacement
Qué necesitas
  1. Samsung BD-F5700 DC Power Board Replacement, DC Power Board: paso 1, imagen 1 de 1
    • Remove the three 10mm screws with a Phillips #0 screwdriver.
    • Pry the top off with a plastic opening tool.
  2. Samsung BD-F5700 DC Power Board Replacement: paso 2, imagen 1 de 1
    • Remove the three screws holding down the cover with a Phillips #0 screwdriver.
  3. Samsung BD-F5700 DC Power Board Replacement: paso 3, imagen 1 de 1
    • Lift up the power cord at its base to remove it.
  4. Samsung BD-F5700 DC Power Board Replacement: paso 4, imagen 1 de 1
    • Insert a plastic opening tool into the black plastic tab on the cord and twist to separate.
  5. Samsung BD-F5700 DC Power Board Replacement: paso 5, imagen 1 de 1
    • Remove the 7mm screw with a Phillips #1 screwdriver.
    • Grip the blue tab attached to the base and pull upwards.
  6. Samsung BD-F5700 DC Power Board Replacement: paso 6, imagen 1 de 1
    • Grip the edges of the motherboard and pull upwards to remove.
Conclusión
samer odeh
Miembro Desde 02/13/18
313 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S16-G4, Boczar Spring 2018 Miembro de USF Tampa, Team S16-G4, Boczar Spring 2018
USFT-BOCZAR-S18S16G4
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 10
Todo El Tiempo: 379
