Saltar al contenido principal
Samsung BD-E5400 Wi-Fi Card Replacement
Qué necesitas
  1. Samsung BD-E5400 Wi-Fi Card Replacement, Outer Cover: paso 1, imagen 1 de 2 Samsung BD-E5400 Wi-Fi Card Replacement, Outer Cover: paso 1, imagen 2 de 2
    • Remove the two 10mm Phillips #1 screws.
    • Remove the one 8 mm Phillips #1 screw.
    • Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
  2. Samsung BD-E5400 Wi-Fi Card Replacement: paso 2, imagen 1 de 1
    • Unplug the small wiring bundle attaching the body of the device to the cover.
    • Lay the cover aside.
  3. Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: paso 3, imagen 1 de 3 Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: paso 3, imagen 2 de 3 Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: paso 3, imagen 3 de 3
    • The Wi-Fi card is the light blue component circled in red.
    • Separate the body of the Wi-Fi card from the black plastic cover.
    • Unplug the wires of the Wi-Fi card from the motherboard.
Conclusión
Cameron Herring
Miembro Desde 08/28/18
306 Reputación
3 Guías creadas
Equipo
IUPUI, Team S1-G3, Arle Fall 2018 Miembro de IUPUI, Team S1-G3, Arle Fall 2018
IUPUI-ARLE-F18S1G3
3 Miembros
4 Guías creadas
Un comentario
I replaced my wifi card now none of the apps are working. I tried factory reset, and updating firmware nothing. Any ideas to get past this?
mike monroe - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 277
