Saltar al contenido principal
Samsung BD-E5400 Power Cord Replacement
Qué necesitas
  1. Samsung BD-E5400 Power Cord Replacement, Outer Cover: paso 1, imagen 1 de 2 Samsung BD-E5400 Power Cord Replacement, Outer Cover: paso 1, imagen 2 de 2
    • Remove the two 10mm Phillips #1 screws.
    • Remove the one 8 mm Phillips #1 screw.
    • Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
  2. Samsung BD-E5400 Power Cord Replacement: paso 2, imagen 1 de 1
    • Unplug the small wiring bundle attaching the body of the device to the cover.
    • Lay the cover aside.
  3. Samsung BD-E5400 Power Cord Replacement, Power Cord: paso 3, imagen 1 de 2 Samsung BD-E5400 Power Cord Replacement, Power Cord: paso 3, imagen 2 de 2
    • Remove the two 8 mm long, #1 Phillips head screws.
    • Lift up the plastic component cover to remove and lay aside.
  4. Samsung BD-E5400 Power Cord Replacement: paso 4, imagen 1 de 3 Samsung BD-E5400 Power Cord Replacement: paso 4, imagen 2 de 3 Samsung BD-E5400 Power Cord Replacement: paso 4, imagen 3 de 3
    • With the motherboard exposed, locate the point where the power cord is attached.
    • Separate the portion of the cord encased in the black grommet from the frame of the device.
    • Unplug the power cord from the motherboard.
Conclusión
Cameron Herring
Miembro Desde 08/28/18
306 Reputación
3 Guías creadas
Equipo
IUPUI, Team S1-G3, Arle Fall 2018 Miembro de IUPUI, Team S1-G3, Arle Fall 2018
IUPUI-ARLE-F18S1G3
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 352
