Saltar al contenido principal
Samsung BD-D5500 Disc Tray Replacement
Qué necesitas
  1. Samsung BD-D5500 Disc Tray Replacement, Samsung BD-D5500 Disassembly: paso 1, imagen 1 de 1
    • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
  2. Samsung BD-D5500 Disc Tray Replacement: paso 2, imagen 1 de 2 Samsung BD-D5500 Disc Tray Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
    • This is how your device will look after you remove the top.
  3. Samsung BD-D5500 Disc Tray Replacement, Disc Tray: paso 3, imagen 1 de 1
    • To remove the disc hub all you have to do is remove the 4 screws holding it down.
  4. Samsung BD-D5500 Disc Tray Replacement: paso 4, imagen 1 de 1
    • To replace the disc tray open the disk hub and unsnap the sides of the device.
  5. Samsung BD-D5500 Disc Tray Replacement: paso 5, imagen 1 de 1
    • Locate the slider that reads open and close.
    • To open the disc tray slide it to the side that says open.
  6. Samsung BD-D5500 Disc Tray Replacement: paso 6, imagen 1 de 1
    • Return it face up and the disc tray will slide out.
Conclusión
Brandon Nelson
Miembro Desde 01/29/18
109 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 1,044
