Saltar al contenido principal
Samsung Admire Speaker Replacement
Qué necesitas
  1. Samsung Admire Speaker Replacement, Back Cover: paso 1, imagen 1 de 1
    • Use your fingernail or plastic opening tool to pull up the back cover of the phone from under the slit.
  2. Samsung Admire Speaker Replacement, Remove the battery: paso 2, imagen 1 de 1
    • Carefully remove the battery by placing your fingernail underneath the hole and pulling out the battery.
    • Your hands should not be wet.
  3. Samsung Admire Speaker Replacement, Remove the screws: paso 3, imagen 1 de 3 Samsung Admire Speaker Replacement, Remove the screws: paso 3, imagen 2 de 3 Samsung Admire Speaker Replacement, Remove the screws: paso 3, imagen 3 de 3
    • Use the Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
  4. Samsung Admire Speaker Replacement, Inside back cover: paso 4, imagen 1 de 3 Samsung Admire Speaker Replacement, Inside back cover: paso 4, imagen 2 de 3 Samsung Admire Speaker Replacement, Inside back cover: paso 4, imagen 3 de 3
    • Use the plastic opening tools to remove the inside back cover.
    • Place the plastic opening tools on the outside rim of the inside back cover.
    • Carefully lift the cover and circle around the rim to open the inside back cover completely.
    • Carefully disconnect ribbon cables and slowly lift the inside back cover to remove it.
  5. Samsung Admire Speaker Replacement, Speaker: paso 5, imagen 1 de 2 Samsung Admire Speaker Replacement, Speaker: paso 5, imagen 2 de 2
    • The speaker is located within the inside of the back cover.
    • Simply remove it by lifting it off with the plastic opening tool.
Conclusión
2 personas más completaron esta guía.
Thao Uyen Do
Miembro Desde 01/20/15
896 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 7-5, Remmell Winter 2015 Miembro de USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 733
