Saltar al contenido principal
Samsung Ace Display Screen Replacement
Qué necesitas
  1. Samsung Ace Display Screen Replacement, Battery: paso 1, imagen 1 de 3 Samsung Ace Display Screen Replacement, Battery: paso 1, imagen 2 de 3 Samsung Ace Display Screen Replacement, Battery: paso 1, imagen 3 de 3
    • To remove the back casing, firmly press down and push towards the bottom of the phone.
  2. Samsung Ace Display Screen Replacement: paso 2, imagen 1 de 1
    • With the casing removed, lift the battery from the indicated indentation.
  3. Samsung Ace Display Screen Replacement: paso 3, imagen 1 de 1
    • From here, you can now access the SIM card and model/serial numbers.
  4. Samsung Ace Display Screen Replacement, Casing: paso 4, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
  5. Samsung Ace Display Screen Replacement: paso 5, imagen 1 de 2 Samsung Ace Display Screen Replacement: paso 5, imagen 2 de 2
    • Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone.
    • Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
  6. Samsung Ace Display Screen Replacement: paso 6, imagen 1 de 1
    • To remove the SIM card, start by pressing the top of the card and push down and away towards the bottom of the phone. Then, as indicated, pull the SIM card out.
  7. Samsung Ace Display Screen Replacement: paso 7, imagen 1 de 2 Samsung Ace Display Screen Replacement: paso 7, imagen 2 de 2
    • Begin to slowly lift the back casing of the phone. You should hear a snap when the casing is released.
    • The power, volume, and camera buttons may fall out when separating the front and back casing.
  8. Samsung Ace Display Screen Replacement: paso 8, imagen 1 de 1
    • Your casing should be separated and the three loose buttons put to the side.
    • Be aware of the wiring on the top of the phone. Make sure not to pull it apart when separating the case.
  9. Samsung Ace Display Screen Replacement: paso 9, imagen 1 de 2 Samsung Ace Display Screen Replacement: paso 9, imagen 2 de 2
    • Slowly remove the back casing by gently pulling the ribbon connection.
  10. Samsung Ace Display Screen Replacement: paso 10, imagen 1 de 2 Samsung Ace Display Screen Replacement: paso 10, imagen 2 de 2
    • Gently pull on the wires to remove the front casing.
  11. Samsung Ace Display Screen Replacement: paso 11, imagen 1 de 1
    • Your front casing and front speaker are now released.
  12. Samsung Ace Display Screen Replacement, Display Screen: paso 12, imagen 1 de 2 Samsung Ace Display Screen Replacement, Display Screen: paso 12, imagen 2 de 2
    • Locate the display screen.
    • Carefully squeeze part of the flat or pointed edge of the spudger into the spacing under the glass display to pry and lift the display up.
    • It may help to insert the pointed edge of the spudger into the small indentation shown on the right in the second image.
  13. Samsung Ace Display Screen Replacement: paso 13, imagen 1 de 3 Samsung Ace Display Screen Replacement: paso 13, imagen 2 de 3 Samsung Ace Display Screen Replacement: paso 13, imagen 3 de 3
    • Slide the spudger across the bottom of the display and slowly push up.
  14. Samsung Ace Display Screen Replacement: paso 14, imagen 1 de 1
    • Slowly pry the spudger up to remove the display.
  15. Samsung Ace Display Screen Replacement: paso 15, imagen 1 de 1
    • To remove the casing as a whole, slowly lift up and towards the right side of the phone.
    • Be aware of the wiring on the right side of the phone connecting the display.
Conclusión
Breanne
Miembro Desde 04/12/12
187 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-24, Amido Spring 2012 Miembro de Cal Poly, Team 6-24, Amido Spring 2012
CPSU-AMIDO-S12S6G24
3 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 1,508
