Introducción
If your current case is damaged, this guide will help you install a new case to protect your phone from further abuse.
Qué necesitas
To remove the back casing, firmly press down and push towards the bottom of the phone.
Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
Casi Terminas!
Conclusión
