Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung ATIV Smart PC 500T Right Speaker Replacement
Qué necesitas
  1. Samsung ATIV Smart PC 500T Right Speaker Replacement, Backplate: paso 1, imagen 1 de 2 Samsung ATIV Smart PC 500T Right Speaker Replacement, Backplate: paso 1, imagen 2 de 2
    • Remove the stylus from the device.
    • Place the device screen-up on a hard surface, like a table.
  2. Samsung ATIV Smart PC 500T Right Speaker Replacement: paso 2, imagen 1 de 3 Samsung ATIV Smart PC 500T Right Speaker Replacement: paso 2, imagen 2 de 3 Samsung ATIV Smart PC 500T Right Speaker Replacement: paso 2, imagen 3 de 3
    • Insert a plastic pry tool or opening pick between the glass and plastic case.
    • Work your way around the plastic edge, unclipping the backplate.
    • Once the clips are loosened, remove the backplate. Some force may be necessary.
    • Though you may need to use force, be careful of the pry tool slipping and hurting you!
  3. Samsung ATIV Smart PC 500T Right Speaker Replacement, Battery: paso 3, imagen 1 de 3 Samsung ATIV Smart PC 500T Right Speaker Replacement, Battery: paso 3, imagen 2 de 3 Samsung ATIV Smart PC 500T Right Speaker Replacement, Battery: paso 3, imagen 3 de 3
    • Disconnect the three ribbon cables from the motherboard to free the battery.
    • Use your finger to lift the flap securing each ZIF connector.
    • Slide the ribbon cable out and towards you. Now it should be completely detached.
    • Repeat with the other two cables.
  4. Samsung ATIV Smart PC 500T Right Speaker Replacement: paso 4, imagen 1 de 3 Samsung ATIV Smart PC 500T Right Speaker Replacement: paso 4, imagen 2 de 3 Samsung ATIV Smart PC 500T Right Speaker Replacement: paso 4, imagen 3 de 3
    • Get a firm hold of the power cable as close to the clip as you can.
    • Pull the power cable up and out of the clip.
  5. Samsung ATIV Smart PC 500T Right Speaker Replacement: paso 5, imagen 1 de 3 Samsung ATIV Smart PC 500T Right Speaker Replacement: paso 5, imagen 2 de 3 Samsung ATIV Smart PC 500T Right Speaker Replacement: paso 5, imagen 3 de 3
    • Remove the six 3.5-mm screws using the Phillips #00 screwdriver.
    • Lift the battery out by hooking your finger under the tab on the top side of the battery and pulling it up and towards you. The battery should come out easily.
  6. Samsung ATIV Smart PC 500T Right Speaker Replacement, Right Speaker: paso 6, imagen 1 de 2 Samsung ATIV Smart PC 500T Right Speaker Replacement, Right Speaker: paso 6, imagen 2 de 2
    • Locate the right speaker.
    • The right speaker is labeled with an "R."
    • Locate the 3.5-mm screws and remove them with the Phillips #00 Screwdriver.
  7. Samsung ATIV Smart PC 500T Right Speaker Replacement: paso 7, imagen 1 de 1
    • Lift and remove the speaker from the device once the screws have been removed.
Conclusión
Equipo
Baylor, Team 6-6, Williams Fall 2015 Miembro de Baylor, Team 6-6, Williams Fall 2015
BU-WILLIAMS-F15S6G6
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 39
Todo El Tiempo: 1,329
