Saltar al contenido principal
Samsung ATIV Smart PC 500T Battery Replacement
Qué necesitas
  1. Samsung ATIV Smart PC 500T Battery Replacement, Backplate: paso 1, imagen 1 de 2 Samsung ATIV Smart PC 500T Battery Replacement, Backplate: paso 1, imagen 2 de 2
    • Remove the stylus from the device.
    • Place the device screen-up on a hard surface, like a table.
  2. Samsung ATIV Smart PC 500T Battery Replacement: paso 2, imagen 1 de 3 Samsung ATIV Smart PC 500T Battery Replacement: paso 2, imagen 2 de 3 Samsung ATIV Smart PC 500T Battery Replacement: paso 2, imagen 3 de 3
    • Insert a plastic pry tool or opening pick between the glass and plastic case.
    • Work your way around the plastic edge, unclipping the backplate.
    • Once the clips are loosened, remove the backplate. Some force may be necessary.
    • Though you may need to use force, be careful of the pry tool slipping and hurting you!
  3. Samsung ATIV Smart PC 500T Battery Replacement, Battery: paso 3, imagen 1 de 3 Samsung ATIV Smart PC 500T Battery Replacement, Battery: paso 3, imagen 2 de 3 Samsung ATIV Smart PC 500T Battery Replacement, Battery: paso 3, imagen 3 de 3
    • Disconnect the three ribbon cables from the motherboard to free the battery.
    • Use your finger to lift the flap securing each ZIF connector.
    • Slide the ribbon cable out and towards you. Now it should be completely detached.
    • Repeat with the other two cables.
  4. Samsung ATIV Smart PC 500T Battery Replacement: paso 4, imagen 1 de 3 Samsung ATIV Smart PC 500T Battery Replacement: paso 4, imagen 2 de 3 Samsung ATIV Smart PC 500T Battery Replacement: paso 4, imagen 3 de 3
    • Get a firm hold of the power cable as close to the clip as you can.
    • Pull the power cable up and out of the clip.
  5. Samsung ATIV Smart PC 500T Battery Replacement: paso 5, imagen 1 de 3 Samsung ATIV Smart PC 500T Battery Replacement: paso 5, imagen 2 de 3 Samsung ATIV Smart PC 500T Battery Replacement: paso 5, imagen 3 de 3
    • Remove the six 3.5-mm screws using the Phillips #00 screwdriver.
    • Lift the battery out by hooking your finger under the tab on the top side of the battery and pulling it up and towards you. The battery should come out easily.
Conclusión
13 personas más completaron esta guía.
Crystal Dinh
Miembro Desde 09/23/15
1,026 Reputación
4 Guías creadas
Equipo
Baylor, Team 6-6, Williams Fall 2015 Miembro de Baylor, Team 6-6, Williams Fall 2015
BU-WILLIAMS-F15S6G6
3 Miembros
10 Guías creadas
5 comentarios
Thanks! Now i won't screw it up asm's destroy expensive technology like i normally do fumbling my way through these types of things!
lynz318 - Contestar
Awesome! Thanks for this! I managed to replace the battery, but it still won't power on. It was water damaged a while back. Any ideas on next component to try replacing?
joeshuer - Contestar
Do you have a battery for the Samsung ATIV Smart PC 700T1C?
calebjmartin - Contestar
If you're lucky, you'll replace the battery & off you go.
Unfortunately, a whole LOT of folks do this, to no avail.
If you pop for the new battery, keep the packing as new as you can in case it's NOT the issue-- at least you might recoup some of the money on Ebay.
After that, also sell your tablet on Ebay for parts because, with some units, you can change out parts all day long & it'll just never run again. Better to count your losses & do some homework this time to hopefully buy a more dependable product.
This series is just shocking at how many people have dead tablets in TWO years!
Shame on Samsung, for not recalling them. I guess they're big enough not to care....
girldownunder - Contestar
I got my ativ500t last 2014. After a year, the dock is not working anymore. I went to the service center and paid because it's beyond warranty, but they could not solve the problem. They told me the motherboard was broken. After a yr?! Motherboard broken?! Since I cannot do anything about it, I just ditched the dock and used it as a tab, but less frequently. Now, after barely 3 yrs, it will not turn on. Nothing happened to it. It did not get wet or fell. It just fell dead suddenly. I cannot bear to say this, but I was wrong when I purchased this product. I did not get the value I paid for. It is on the pricey tablet pcs, but it did not even last for 3 full yrs considering I do not even use it that much because I have a PC and smartphone. I am very disappointed with samsung and its service center. Shame.
Razel Elaine Grace Cataluña - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 51
Todo El Tiempo: 18,857
