Saltar al contenido principal
Samsung ATIV Book 9 Speaker Replacement
Qué necesitas
  1. Samsung ATIV Book 9 Speaker  Replacement, Speaker: paso 1, imagen 1 de 2 Samsung ATIV Book 9 Speaker  Replacement, Speaker: paso 1, imagen 2 de 2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using the Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Speaker  Replacement: paso 2, imagen 1 de 3 Samsung ATIV Book 9 Speaker  Replacement: paso 2, imagen 2 de 3 Samsung ATIV Book 9 Speaker  Replacement: paso 2, imagen 3 de 3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Speaker  Replacement: paso 3, imagen 1 de 3 Samsung ATIV Book 9 Speaker  Replacement: paso 3, imagen 2 de 3 Samsung ATIV Book 9 Speaker  Replacement: paso 3, imagen 3 de 3
    • Using the Phillips #0, remove the seven 5mm screws highlighted in the image.
    • Using your hands, disconnect the battery's main cord from the main motherboard.
    • Using your hands, remove the battery from the computer.
  4. Samsung ATIV Book 9 Speaker  Replacement: paso 4, imagen 1 de 3 Samsung ATIV Book 9 Speaker  Replacement: paso 4, imagen 2 de 3 Samsung ATIV Book 9 Speaker  Replacement: paso 4, imagen 3 de 3
    • Using a Phillips #1, remove the two 3mm screws, one per speaker.
    • Using the nylon spudger, release the black and red wires that connect the two speakers.
  5. Samsung ATIV Book 9 Speaker  Replacement: paso 5, imagen 1 de 3 Samsung ATIV Book 9 Speaker  Replacement: paso 5, imagen 2 de 3 Samsung ATIV Book 9 Speaker  Replacement: paso 5, imagen 3 de 3
    • Using your hands, remove the cord that connects the speakers to the board you are removing.
    • Do not pull on the cord as that might damage it; remove it by pulling on the white wire head.
    • Using your hands remove the speakers from the computer. This may require some force as they are held in place partially by double sided tape.
Conclusión
Phat Tran
Miembro Desde 09/16/18
786 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 563
