Saltar al contenido principal
Samsung ATIV Book 9 Plus Speakers Replacement
Qué necesitas
  1. Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: paso 1, imagen 1 de 3 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: paso 1, imagen 2 de 3 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: paso 1, imagen 3 de 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Speakers Replacement: paso 2, imagen 1 de 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: paso 3, imagen 1 de 2 Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: paso 3, imagen 2 de 2
    • The speakers are black, and form a block-like "L" shape around the bottom half of the battery.
    • Lift from the corners of the speakers to remove them.
  4. Samsung ATIV Book 9 Plus Speakers Replacement: paso 4, imagen 1 de 2 Samsung ATIV Book 9 Plus Speakers Replacement: paso 4, imagen 2 de 2
    • After lifting the body of the speaker out of the laptop, you will notice that the top of the speaker is connected to the laptop by cables.
    • Continue removing the speakers by gently squeezing the sides of the white connector.
  5. Samsung ATIV Book 9 Plus Speakers Replacement: paso 5, imagen 1 de 1
    • Gently tug on the white connector in order to remove the speakers.
Conclusión
Karoline DaVee
Miembro Desde 03/20/15
136 Reputación
1 Guía escrita
Equipo
Baylor, Team 2-3, Grigsby Spring 2015 Miembro de Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 1,482
