Saltar al contenido principal
Samsung ATIV Book 9 Plus Screen Replacement
Qué necesitas
  1. Samsung ATIV Book 9 Plus Screen Replacement, Back Cover: paso 1, imagen 1 de 3 Samsung ATIV Book 9 Plus Screen Replacement, Back Cover: paso 1, imagen 2 de 3 Samsung ATIV Book 9 Plus Screen Replacement, Back Cover: paso 1, imagen 3 de 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Screen Replacement: paso 2, imagen 1 de 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Screen Replacement, Screen: paso 3, imagen 1 de 1
    • Disconnect the wire connected at the marked location. This is done by giving it a solid tug parallel with the laptop.
  4. Samsung ATIV Book 9 Plus Screen Replacement: paso 4, imagen 1 de 2 Samsung ATIV Book 9 Plus Screen Replacement: paso 4, imagen 2 de 2
    • Unscrew the three 4.3 mm screws by using a #000 screwdriver located on the hinges in both corners of the laptop.
  5. Samsung ATIV Book 9 Plus Screen Replacement: paso 5, imagen 1 de 2 Samsung ATIV Book 9 Plus Screen Replacement: paso 5, imagen 2 de 2
    • Remove the piece of foam that covers two antenna cable connectors.
    • Use the tip of a spudger or a fingernail to pry straight up and disconnect the antenna cable connectors.
  6. Samsung ATIV Book 9 Plus Screen Replacement: paso 6, imagen 1 de 1
    • Now the screen is completely disconnected and can just be lifted off.
Conclusión
Una persona más ha completado esta guía.
Casey Kauffman
Miembro Desde 11/06/17
329 Reputación
2 Guías creadas
Equipo
IUPUI, Team S6-G6, Baechle Fall 2017 Miembro de IUPUI, Team S6-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G6
Miembros de 3
3 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 2,230
