Saltar al contenido principal
Samsung ATIV Book 9 Plus Heatsink Assembly Replacement
Qué necesitas
  1. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: paso 1, imagen 1 de 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: paso 1, imagen 2 de 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: paso 1, imagen 3 de 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: paso 2, imagen 1 de 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: paso 3, imagen 1 de 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: paso 3, imagen 2 de 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: paso 3, imagen 3 de 3
    • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
    • Gently lift the fans' black connector strip out of the way.
  4. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: paso 4, imagen 1 de 2 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: paso 4, imagen 2 de 2
    • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
  5. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: paso 5, imagen 1 de 1
    • Disconnect the white connectors by gently tugging on them.
    • Lift the fans from their positions.
  6. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Heatsink Assembly: paso 6, imagen 1 de 1
    • Using a Phillips head screwdriver #000 unscrew the motherboard from the rest of the components.
  7. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: paso 7, imagen 1 de 1
    • Disconnect the two cables shown in the picture by gently pulling them off.
  8. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: paso 8, imagen 1 de 1
    • Using a Phillips #000 screwdriver, unscrew the three labeled screws to detach the heatsink assembly.
Conclusión
Ryan Smith
Miembro Desde 04/01/19
193 Reputación
2 Guías creadas
Equipo
IUPUI, Team S7-G7, Wilson Spring 2019 Miembro de IUPUI, Team S7-G7, Wilson Spring 2019
IUPUI-WILSON-S19S7G7
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 630
