Saltar al contenido principal
Samsung ATIV Book 9 Plus Charger Port Replacement
Qué necesitas
  1. Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: paso 1, imagen 1 de 3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: paso 1, imagen 2 de 3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: paso 1, imagen 3 de 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Charger Port Replacement: paso 2, imagen 1 de 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: paso 3, imagen 1 de 2 Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: paso 3, imagen 2 de 2
    • Unscrew the 4.3mm screws holding down the plastic cover using a #000 screwdriver. After the screws are out remove the cover.
    • Remove the 4.3 mm screw holding down the metal cover using a #000 screwdriver.
  4. Samsung ATIV Book 9 Plus Charger Port Replacement: paso 4, imagen 1 de 1
    • Disconnect the charging port from the motherboard by gently tugging on the plastic part of the connection.
  5. Samsung ATIV Book 9 Plus Charger Port Replacement: paso 5, imagen 1 de 1
    • Wedge a plastic opening tool or spudger in between the laptop casing and the port. Pry until you feel it release.
    • This will take some force because the port is glued to the casing.
  6. Samsung ATIV Book 9 Plus Charger Port Replacement: paso 6, imagen 1 de 1
    • Remove the disconnected charger port.
Conclusión
3 personas más completaron esta guía.
Casey Kauffman
Miembro Desde 11/06/17
329 Reputación
2 Guías creadas
Equipo
IUPUI, Team S6-G6, Baechle Fall 2017 Miembro de IUPUI, Team S6-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G6
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 1,923
