Saltar al contenido principal
Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement
Qué necesitas
  1. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement, SSD: paso 1, imagen 1 de 1
    • Remove ten Phillips #00 screws from the back panel.
    • Remove the back panel.
  2. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement: paso 2, imagen 1 de 1
    • Unscrew the five Phillips #00 screws which connect the battery to the frame of the laptop.
    • Lift the battery from the bottom edge, taking care as it is disconnected from the motherboard.
    • During reassembly, insert the top edge of the battery first, aligning the pins of the battery with the pins of the motherboard connection.
  3. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement: paso 3, imagen 1 de 1
    • Remove the interconnect ribbon cable labeled “main” and “sub” by prying the pin connections up with a spudger or plastic opening tool.
  4. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement: paso 4, imagen 1 de 1
    • Remove the single screw holding down the SSD with a Phillips #00 screwdriver.
    • Remove the SSD from its slot located to the right, just above the battery.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 22
Todo El Tiempo: 796
