Saltar al contenido principal
Samsung ATIV Book 9 NP900X3K-S01US Fan Assembly Replacement
Qué necesitas
  1. Samsung ATIV Book 9 NP900X3K-S01US Fan Assembly Replacement, Fan Assembly: paso 1, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the 10 screws holding the back panel together.
    • Remove the back panel.
  2. Samsung ATIV Book 9 NP900X3K-S01US Fan Assembly Replacement: paso 2, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the 4 total screws (2 per each fan).
    • Disconnect the cable connections linking each fan to the motherboard with a spudger.
    • Remove each fan.
Conclusión
To reassemble your device, follow these instructions in reverse order or follow steps 4 to reassemble your laptop.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 327
