Saltar al contenido principal
Samsung ATIV Book 9 NP900X3K-S01US Battery Replacement
Qué necesitas
  1. Samsung ATIV Book 9 NP900X3K-S01US Battery Replacement, Bottom Case: paso 1, imagen 1 de 3 Samsung ATIV Book 9 NP900X3K-S01US Battery Replacement, Bottom Case: paso 1, imagen 2 de 3 Samsung ATIV Book 9 NP900X3K-S01US Battery Replacement, Bottom Case: paso 1, imagen 3 de 3
    • Make sure that the Samsung ATIV Book 9 is powered off and not connected to any power outlets.
    • Close the device and rest it on a flat surface.
    • Flip the device over to access the ten 4.3 mm screws located on the bottom case.
    • Remove all ten screws using the Phillips #00 screwdriver.
  2. Samsung ATIV Book 9 NP900X3K-S01US Battery Replacement: paso 2, imagen 1 de 2 Samsung ATIV Book 9 NP900X3K-S01US Battery Replacement: paso 2, imagen 2 de 2
    • Gently lift and remove the bottom case.
  3. Samsung ATIV Book 9 NP900X3K-S01US Battery Replacement, Battery: paso 3, imagen 1 de 3 Samsung ATIV Book 9 NP900X3K-S01US Battery Replacement, Battery: paso 3, imagen 2 de 3 Samsung ATIV Book 9 NP900X3K-S01US Battery Replacement, Battery: paso 3, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove the six 4.3 mm screws securing the battery to the device.
  4. Samsung ATIV Book 9 NP900X3K-S01US Battery Replacement: paso 4, imagen 1 de 2 Samsung ATIV Book 9 NP900X3K-S01US Battery Replacement: paso 4, imagen 2 de 2
    • Carefully lift the battery out.
Conclusión
Arthur Guz
Miembro Desde 02/05/19
85 Reputación
1 Guía escrita
Equipo
UC Davis, Team S18-G1, Lore Winter 2019 Miembro de UC Davis, Team S18-G1, Lore Winter 2019
UCD-LORE-W19S18G1
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 777
