Saltar al contenido principal
Samsung ATIV Book 9 Lite Hard Drive Replacement
Qué necesitas
  1. Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 2 Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Hard Drive Replacement: paso 2, imagen 1 de 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: paso 2, imagen 2 de 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: paso 2, imagen 3 de 3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Hard Drive Replacement: paso 3, imagen 1 de 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: paso 3, imagen 2 de 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: paso 3, imagen 3 de 3
    • Using your hands or a plastic opening tool, release the yellow motherboard connection strip on both ends by lifting the clamps.
    • Remove the strip to reveal the hard drive.
  4. Samsung ATIV Book 9 Lite Hard Drive Replacement: paso 4, imagen 1 de 2 Samsung ATIV Book 9 Lite Hard Drive Replacement: paso 4, imagen 2 de 2
    • Using a Phillips #0, remove the two 3mm screws holding the hard drive in place.
    • Remove the hard drive by pulling it out with your hands.
Conclusión
2 personas más completaron esta guía.
Phat Tran
Miembro Desde 09/16/18
786 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 35
Todo El Tiempo: 4,547
