Saltar al contenido principal
Samsung ATIV Book 9 Lite Battery Replacement
Qué necesitas
  1. Samsung ATIV Book 9 Lite Battery Replacement, Battery: paso 1, imagen 1 de 2 Samsung ATIV Book 9 Lite Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Battery Replacement: paso 2, imagen 1 de 3 Samsung ATIV Book 9 Lite Battery Replacement: paso 2, imagen 2 de 3 Samsung ATIV Book 9 Lite Battery Replacement: paso 2, imagen 3 de 3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Battery Replacement: paso 3, imagen 1 de 3 Samsung ATIV Book 9 Lite Battery Replacement: paso 3, imagen 2 de 3 Samsung ATIV Book 9 Lite Battery Replacement: paso 3, imagen 3 de 3
    • Using a Phillips #0, remove the seven 5mm screws highlighted in the image.
    • Using your hands, disconnect the battery's main cord from the main motherboard.
  4. Samsung ATIV Book 9 Lite Battery Replacement: paso 4, imagen 1 de 2 Samsung ATIV Book 9 Lite Battery Replacement: paso 4, imagen 2 de 2
    • Using your hands remove the battery from the computer.
Conclusión
3 personas más completaron esta guía.
Phat Tran
Miembro Desde 09/16/18
786 Reputación
5 Guías creadas
Equipo
2 comentarios
please where can i get the battery 🔋
Bethel Ugwudike - Contestar
Please where can i get the battery for Samsung 930x5j910s5j940x5j
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 1,676
