Saltar al contenido principal
Samsung ATIV Book 9 Lite Audio Port Replacement
Qué necesitas
  1. Samsung ATIV Book 9 Lite Audio Port Replacement, Audio Port/USB2/Display Port Board: paso 1, imagen 1 de 2 Samsung ATIV Book 9 Lite Audio Port Replacement, Audio Port/USB2/Display Port Board: paso 1, imagen 2 de 2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Audio Port Replacement: paso 2, imagen 1 de 3 Samsung ATIV Book 9 Lite Audio Port Replacement: paso 2, imagen 2 de 3 Samsung ATIV Book 9 Lite Audio Port Replacement: paso 2, imagen 3 de 3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Audio Port Replacement: paso 3, imagen 1 de 3 Samsung ATIV Book 9 Lite Audio Port Replacement: paso 3, imagen 2 de 3 Samsung ATIV Book 9 Lite Audio Port Replacement: paso 3, imagen 3 de 3
    • Using your hands move the black and white wires that are layered on top of the board to be out of the way of the removal.
    • Using a Phillips #0, remove three 3.5mm screws.
  4. Samsung ATIV Book 9 Lite Audio Port Replacement: paso 4, imagen 1 de 2 Samsung ATIV Book 9 Lite Audio Port Replacement: paso 4, imagen 2 de 2
    • Using your hands remove the cord that connects the speakers to the board you are removing.
    • Do not pull on the cord as that might damage it; remove it by pulling on the white wire head.
    • Using your hands, remove the board from the computer.
Conclusión
Phat Tran
Miembro Desde 09/16/18
786 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 485
