Introducción
This guide will allow the user to remove and replace the touchscreen device used by the Samsung ATIV Book 7 NP740U3E-K01UB. By working through this guide, the user will develop an understand the composition of the screen assembly and learn how the components can be removed and replaced.
Qué necesitas
Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
Disconnect the databus from the motherboard as seen in the lower left of the picture
Disconnect the white and black wire from the graphics card as seen in the middle of the photo. (Note: These two wires are connected to the motherboard by means of snap-in male-female copper connectors, meaning they can be disconnected by un-snapping the connectors.
Important Note: When re-assembling the screen assembly, additional adhesive glue may be needed to adhere the capacitive touch-screen and screen cover back onto the original assembly.
Una persona más ha completado esta guía.
