Saltar al contenido principal
Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement
Qué necesitas
  1. Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement, Backplate: paso 1, imagen 1 de 2 Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement, Backplate: paso 1, imagen 2 de 2
    • Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
  2. Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement: paso 2, imagen 1 de 1
    • Remove the backplate.
  3. Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement, Touch-Screen: paso 3, imagen 1 de 1
    • Disconnect the databus from the motherboard as seen in the lower left of the picture
    • Disconnect the white and black wire from the graphics card as seen in the middle of the photo. (Note: These two wires are connected to the motherboard by means of snap-in male-female copper connectors, meaning they can be disconnected by un-snapping the connectors.
  4. Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement: paso 4, imagen 1 de 1
    • Using the Phillips #000 screwdriver, remove six 5mm screws.
    • These screws hold the screen assembly into place with the motherboard / electronics assembly.
  5. Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement: paso 5, imagen 1 de 1
    • Now that the six 5mm screws were removed, remove and separate the screen assembly as seen in the image.
    • As seen in the next step, the backplate of the screen assembly will be removed. There is no hardware keeping this in place except for adhesive glue. Therefore the screen assembly backplate will be gently pried free.
  6. Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement: paso 6, imagen 1 de 1
    • The screen assembly backplate is to be removed
    • The backplate is adhered around the edges. Using a flat-wedged tool, gently pry the backplate free from the assembly.
  7. Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement: paso 7, imagen 1 de 2 Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement: paso 7, imagen 2 de 2
    • Now that backplate has been removed, flip the laptop over on the front. Remove the capacitive touch screen.
    • Similarly to how the backplate was adhered with glue, this touch screen is adhered to the graphics screen of this device. As seen in the second photo, the touch screen should be gently separated from the graphics screen. Make sure to disconnect the ribbon as circle in the photo.
Conclusión
Important Note: When re-assembling the screen assembly, additional adhesive glue may be needed to adhere the capacitive touch-screen and screen cover back onto the original assembly.
Una persona más ha completado esta guía.
Liam
Miembro Desde 03/26/19
223 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 487
