Saltar al contenido principal
Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement
Qué necesitas
  1. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement, Backplate: paso 1, imagen 1 de 2 Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement, Backplate: paso 1, imagen 2 de 2
    • Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
  2. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the backplate.
  3. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the six 5mm screws that hold the battery by using the Phillips #0 screwdriver.
  4. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: paso 4, imagen 1 de 1
    • Disconnect the battery from the motherboard and remove the battery.
  5. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement, Speaker: paso 5, imagen 1 de 1
    • There are two speakers which are found on the lower left and right side of the laptop, beside the battery.
  6. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: paso 6, imagen 1 de 3 Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: paso 6, imagen 2 de 3 Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: paso 6, imagen 3 de 3
    • Remove the screws of the motherboard to disconnect the motherboard from the speakers using a Phillips #0 screwdriver.
  7. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: paso 7, imagen 1 de 1
    • Remove the 4 mm screw with the Phillips #000 screwdriver and remove the speaker.
Conclusión
Una persona más ha completado esta guía.
Alexander Nwonye
Miembro Desde 03/21/19
127 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 106
