Saltar al contenido principal
Samsung ATIV Book 4 Screen Replacement
Qué necesitas
  1. Samsung ATIV Book 4 Screen Replacement, Screen: paso 1, imagen 1 de 2 Samsung ATIV Book 4 Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Be sure the computer is off, and open the computer so that the screen is showing.
    • Use the plastic opening tool and pry away the casing surrounding the screen. Remove the casing entirely.
  2. Samsung ATIV Book 4 Screen Replacement: paso 2, imagen 1 de 1
    • Remove the four 3.5mm screws securing the screen.
    • Tilt the screen back before removing the screws, there is a possibility it could fall and damage your keyboard or the ribbon cable connected to it.
  3. Samsung ATIV Book 4 Screen Replacement: paso 3, imagen 1 de 1
    • Place the screen gently on the keyboard.
  4. Samsung ATIV Book 4 Screen Replacement: paso 4, imagen 1 de 1
    • Remove the ribbon cable from the screen.
    • Remove and replace the screen.
Conclusión
Daniel
Miembro Desde 03/19/15
342 Reputación
3 Guías creadas
Equipo
Un comentario
Where do you buy the replacement screen for the ATIV Book 4? Thanks!
RMS015 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 13
Todo El Tiempo: 3,346
