Saltar al contenido principal
Samsung ATIV Book 4 Mouse Pad Replacement
Qué necesitas
  1. Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: paso 1, imagen 1 de 3 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: paso 1, imagen 2 de 3 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: paso 1, imagen 3 de 3
    • Place the computer upside down.
    • Remove the two rubber pads, by prying up on them.
    • There may be adhesive holding them down.
    • Remove the seven 6.5mm screws on exterior of computer.
    • Remove panel by sliding it down and lifting it away from the computer.
  2. Samsung ATIV Book 4 Mouse Pad Replacement: paso 2, imagen 1 de 1
    • Remove the four 4.4mm screws that are underneath the panel.
    • Remove the two 6.5mm screws that were underneath the rubber pads.
  3. Samsung ATIV Book 4 Mouse Pad Replacement: paso 3, imagen 1 de 2 Samsung ATIV Book 4 Mouse Pad Replacement: paso 3, imagen 2 de 2
    • Using plastic opening tool, pry plastic panel away from computer.
    • Start prying at one point and work your way around the entire computer until panel is free come computer.
    • Remove the panel from computer once all tabs are broke free.
  4. Samsung ATIV Book 4 Mouse Pad Replacement: paso 4, imagen 1 de 2 Samsung ATIV Book 4 Mouse Pad Replacement: paso 4, imagen 2 de 2
    • Pull this tab outwards, as shown, to release the wire harness.
    • With the tab now pulled out, pull lightly on the blue tape, to remove the harness.
    • Pull on the blue tape to remove wire harness.
    • This harness may require a little more force to remove, but will slide right out.
    • Remove the two 3.5mm screws and remove the defective hardware.
    • This step may be easier if the battery is taken out. Follow the battery replacement guide to do so.
Conclusión
Daniel
Miembro Desde 03/19/15
342 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 1,092
