Saltar al contenido principal
Samsung ASV09PSBAN Circuit Board Replacement
Qué necesitas
  1. Samsung ASV09PSBAN Circuit Board Replacement, Circuit Board: paso 1, imagen 1 de 1
    • Turn off the power from the circuit breaker.
  2. Samsung ASV09PSBAN Circuit Board Replacement: paso 2, imagen 1 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 2, imagen 2 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 2, imagen 3 de 3
    • Carefully remove the front grille panel by placing your hands at the top of the air intake cover.
  3. Samsung ASV09PSBAN Circuit Board Replacement: paso 3, imagen 1 de 1
    • Use your hands to remove the air filters.
    • Clean the air intake screen with a vacuum if necessary.
  4. Samsung ASV09PSBAN Circuit Board Replacement: paso 4, imagen 1 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 4, imagen 2 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 4, imagen 3 de 3
    • Remove the screw from the small panel on the right side.
    • Remove the cover.
  5. Samsung ASV09PSBAN Circuit Board Replacement: paso 5, imagen 1 de 2 Samsung ASV09PSBAN Circuit Board Replacement: paso 5, imagen 2 de 2
    • Disconnect the black wire from the unit.
  6. Samsung ASV09PSBAN Circuit Board Replacement: paso 6, imagen 1 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 6, imagen 2 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 6, imagen 3 de 3
    • Disconnect the two parts of the white wire.
  7. Samsung ASV09PSBAN Circuit Board Replacement: paso 7, imagen 1 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 7, imagen 2 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 7, imagen 3 de 3
    • Remove two screws from each side of the front panel.
  8. Samsung ASV09PSBAN Circuit Board Replacement: paso 8, imagen 1 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 8, imagen 2 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 8, imagen 3 de 3
    • Completely remove the front panel.
    • If you can not remove it easily, use a spudger to carefully pry it open.
  9. Samsung ASV09PSBAN Circuit Board Replacement: paso 9, imagen 1 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 9, imagen 2 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 9, imagen 3 de 3
    • Remove the old circuit board from the three notches holding it in place.
    • Thread the bundled white wire through the slot and remove the circuit board completely from the unit.
    • Install a new circuit board.
  10. Samsung ASV09PSBAN Circuit Board Replacement: paso 10, imagen 1 de 2 Samsung ASV09PSBAN Circuit Board Replacement: paso 10, imagen 2 de 2
    • Reinstall the front panel.
    • Replace the two screws on each side of the front panel.
  11. Samsung ASV09PSBAN Circuit Board Replacement: paso 11, imagen 1 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 11, imagen 2 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 11, imagen 3 de 3
    • Reconnect the white wires.
    • Thread the black wire through the slots.
  12. Samsung ASV09PSBAN Circuit Board Replacement: paso 12, imagen 1 de 1
    • Reinstall the small cover.
  13. Samsung ASV09PSBAN Circuit Board Replacement: paso 13, imagen 1 de 2 Samsung ASV09PSBAN Circuit Board Replacement: paso 13, imagen 2 de 2
    • Reinstall the filter.
  14. Samsung ASV09PSBAN Circuit Board Replacement: paso 14, imagen 1 de 2 Samsung ASV09PSBAN Circuit Board Replacement: paso 14, imagen 2 de 2
    • Restore the power to check if the unit is functioning.
  15. Samsung ASV09PSBAN Circuit Board Replacement: paso 15, imagen 1 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 15, imagen 2 de 3 Samsung ASV09PSBAN Circuit Board Replacement: paso 15, imagen 3 de 3
    • If the unit is functioning, turn the fan off, and reinstall the front grille panel.
    • At the end, you can turn it on again.
Linea de Meta
Una persona más ha completado esta guía.
Jenny
Miembro Desde 03/22/21
269 Reputación
1 Guía escrita
Equipo
Un comentario
I am having problem like different way, if I set temperature from 23'C to 17'C than only outdoor unit (compressor unit) start working. Even though it's started, but I feel the temperature like 29 'C only. What will be the problem? Suggest me..
Kishore Kumar S - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 70
Todo El Tiempo: 1,791
