Introducción
This guide will assist you on replacing a Samsung Remote Model# AH59-02408A’s circuit board. When TV remotes are not functioning, people tend to fear that they cannot fix them because the procedure is too advanced, therefore they resort to buying a replacement remote. However, our tutorial will show you how simple and quick the process of replacing your circuit board is.
*Additional Details/Tips:
- You will not require any tools for this process apart from your replacement circuit board.
- Good organization and reading skills will help you get through the steps quicker
- It is recommended that you perform the replacement in a lighted workspace as it will greatly help you with identifying small alignment nodes/holes.
Separate the front and back case with your hands. Grip it by the seam and open it up gently.
