Introducción
By: Nathan Zimmerer, Peter Rubis, Paul Biggins, and Brad Funsten.
This guide could be used to replace the blown capacitors on this board. It is suggested that a whole new replacement board
Qué necesitas
You will need a phillips screwdriver and a replacement power board which can be ordered online 1. First, place the monitor face down, then remove the plastic covering if it’s on Once this is done remove the three screws shown below. Once these screws are removed, the stand is able to be removed.
12 personas más completaron esta guía.
