Saltar al contenido principal
Samsung 500C ChromeBook WIreless Card Replacement
Qué necesitas
  1. Samsung 500C ChromeBook WIreless Card Replacement, Wireless Card: paso 1, imagen 1 de 2 Samsung 500C ChromeBook WIreless Card Replacement, Wireless Card: paso 1, imagen 2 de 2
    • Remove the back panel of the device by taking out the seven screws on the back panel of the device.
    • Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
  2. Samsung 500C ChromeBook WIreless Card Replacement: paso 2, imagen 1 de 3 Samsung 500C ChromeBook WIreless Card Replacement: paso 2, imagen 2 de 3 Samsung 500C ChromeBook WIreless Card Replacement: paso 2, imagen 3 de 3
    • Locate the wireless card. It is shown highlighted in picture one.
    • Detach the black and white cords connected to the wireless card and unscrew the screw holding in the card. They are shown highlighted in picture two.
    • Pull the card out of its slot and insert the new card. Reattach the wires and reassemble the device. Note: the white wire connects to the terminal closer to the screw and the black to the other terminal.
Conclusión
Garrett Kissinger
Miembro Desde 02/24/14
704 Reputación
5 Guías creadas
Equipo
Michigan Tech, Team 1-2, Lauer Spring 2014 Miembro de Michigan Tech, Team 1-2, Lauer Spring 2014
MTU-LAUER-S14S1G2
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 18
Todo El Tiempo: 1,853
