Qué necesitas
Remove the back panel of the device by taking out the seven screws on the back panel of the device.
Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
Note: The Speaker is held in with an adhesive back so some force will be needed to remove it.
Remove the speaker using a spudger and detach the cord connected to it from the laptop. The speaker location is seen highlighted in picture 1.
Attach the cord of your replacement speaker and reassemble the device.
