Saltar al contenido principal
Samsung 500C ChromeBook Internal Speakers Replacement
Qué necesitas
  1. Samsung 500C ChromeBook Internal Speakers Replacement, Internal Speakers: paso 1, imagen 1 de 2 Samsung 500C ChromeBook Internal Speakers Replacement, Internal Speakers: paso 1, imagen 2 de 2
    • Remove the back panel of the device by taking out the seven screws on the back panel of the device.
    • Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
  2. Samsung 500C ChromeBook Internal Speakers Replacement: paso 2, imagen 1 de 2 Samsung 500C ChromeBook Internal Speakers Replacement: paso 2, imagen 2 de 2
    • Note: The Speaker is held in with an adhesive back so some force will be needed to remove it.
    • Remove the speaker using a spudger and detach the cord connected to it from the laptop. The speaker location is seen highlighted in picture 1.
    • Attach the cord of your replacement speaker and reassemble the device.
Conclusión
Garrett Kissinger
Miembro Desde 02/24/14
704 Reputación
5 Guías creadas
Equipo
Michigan Tech, Team 1-2, Lauer Spring 2014 Miembro de Michigan Tech, Team 1-2, Lauer Spring 2014
MTU-LAUER-S14S1G2
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 954
