Saltar al contenido principal
Samsung 351U Keyboard Key Replacement
Qué necesitas
  1. Samsung 351U Keyboard Key Replacement, Keyboard Key: paso 1, imagen 1 de 1
    • Select the key you would like to remove then slide the plastic opening tool beneath it until you hear a pop.
  2. Samsung 351U Keyboard Key Replacement: paso 2, imagen 1 de 1
    • The key is now out and ready to be removed/replaced.
    • Be sure to only remove one key at a time so they will be in the same place as they were.
    • Clean the key and replace it into the same spot until another pop is heard.
Conclusión
Melvin Nelson
Miembro Desde 02/15/17
326 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 12-4, Eyestone Spring 2017 Miembro de USF Tampa, Team 12-4, Eyestone Spring 2017
USFT-EYESTONE-S17S12G4
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 676
