Introducción
The motherboard is the electronic hub inside the monitor connecting each of its electrical components, including the navigation button, the screen, and the HDMI/VGA ports.
Qué necesitas
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
Herramienta utilizada en este paso:Heavy-Duty Spudger$4.99
Insert the heavy duty spudger in between the monitors back panel and its frame.
Use the heavy duty spudger to pry open the back panel.
Remove the navigation button connector by pulling while holding down its thumb tab.
Una persona más ha completado esta guía.
